TallyDrive — Your Business Data, Always Safe . Always Accessible.
Renew TSS to use cloud backups, anytime access & free storage.
Simplified business solutions
Why TallyDrive?
TallyDrive helps you keep your business data safe, accessible, and always ready with secure cloud backups. Just set it once and let TallyDrive handle the rest.
With an active TSS subscription, you get free cloud storage:
  • 1 GB for Single-user TallyPrime
  • 3 GB for Multi-user TallyPrime
With automated scheduling, easy restoration, and reliable storage on cloud, you can protect your financial data without any extra effort.
Key benefits
Your Tally data stays safe, backed up, and ready whenever you need it — no manual effort, no tension.
Set your preferred schedule — daily, weekly or monthly.
TallyPrime will back up your company data automatically to:
  • Your local drive, or
  • TallyDrive (recommended)
  • You focus on business. Tally takes care of the rest.
Made a mistake? Need older data?
Restore:
  • The latest backup, or
  • Any previous version (incremental backups)
Full control. Zero stress.
With incremental backups, only the changes since the last backup are saved. This keeps backup time fast and reduces storage usage — perfect for busy businesses.
Your Tally backups are stored on Tally’s secure cloud, ensuring:
  • High availability
  • Safe access
  • Zero risk of local machine failures
Why Renew TSS Today?
Because TallyDrive works only with active TSS. When TSS expires:
  • Access to TallyDrive stops
  • Your data remains stored only for 90 days
  • You miss out on free storage & secure backups
  • Renew TSS before expiry to keep your cloud backups running smoothly.
Try how TallyDrive works
TallyDrive keeps your data protected in the cloud so your business never stops.
Watch Demo   icons
FAQ
You can schedule automatic backups in TallyPrime and choose TallyDrive as the backup destination. Once set up, your data is backed up to the cloud automatically based on the schedule you select.
Yes. TallyDrive uses secure cloud infrastructure from Tally, ensuring your data is protected against system crashes, accidental deletion, hardware issues, or local machine failures.
Yes. TallyDrive works only with an active TSS subscription. Without TSS, access stops and your data stays stored for only 90 days.
You get free storage with an active TSS:
  • 1 GB for Single-User TallyPrime
  • 3 GB for Multi-User TallyPrime
You can start using this instantly after renewing TSS.
You can restore your latest backup or choose a previous version directly from TallyDrive. Version-based restore helps recover data from any point in your backup history.
Your TallyDrive data stays safe for 90 days after TSS expiry. However, you cannot access or create new backups until you renew your TSS
Need More Storage?
If your free storage (1 GB/3 GB) runs out, simply purchase more.
Starting at ₹1200/year for 10 GB, you can expand as your business grows.
Buy now   icons
